Originally Posted by jpristel
Yeah, I've noticed that almost all the scanners are based on the elm 327 chip. However the device from Vital Engineering appears to be the cheapest all around OBD dongles I've found yet. Have you had luck using the elm chips on other automobiles?
Yeah, the 323 (VPW) worked on the PT Cruiser and the 322 (ISO) worked on,a Citroen Xara and a Peugeot 307. The 327 (multi) works on the Xfire if you select the fast init ISO protocol (No. 5 I think it was).
Edit: Just thought I better add that although I got the 327 to communicate with the car it was with a terminal emulator only. I couldn't connect to the car using the free Scantool.net software - I always got an initialization error irrespective of whether the engine was running or not.
Simon.
