Old May 8, 2013 | 05:42 PM
  #87 (permalink)
ala_xfire
Default Re: Rough Idle and Limp Power
I am not sure what the difference can be, MB does not change the number of a part for no good reason. If a part fits another series of cars the number will not change from its original number, if there is a slight upgrade then the last four numbers are the first to change, a small change would be a change in the last two numbers.
Basically if a part was made for a very early car and it fitted a modern car with no alterations to it the number would be the same. Same number = same part.
I do not think there should be another identical part in the system with a different part number, although I'm sure it could happen.
No argument, I just know it worked for me.
This is not to say others won't have a problem ......
