Re: SC Pulley and Crank Upgrade?
Yeah, I'm kinda with Steve on this one. However...
Short answer, yes you can do it: with proper fueling, cooling mods and tuning to support it.
But does the gain outweigh the negatives? You will be spinning your supercharger outside of it's efficiency range. This generates a LOT of heat and will lead to premature failure. In addition, if you don't have a way to bring the air temps down, it will hurt performance.
As mentioned, there are a bunch of threads on this with peoples experiences. Do a search and enjoy the read. There are people on both sides of the fence on this topic. But in the end, it's how much do you want to spend and can you afford to rebuild your motor should it fail?
