Re: Has anyone replaced either of their ABS rear speed sensors?
Anyway if you are on the drivers side with the hood open you will see a silver aluminum square with all the brake lines running to it that is the antilock brake controller. It has a black plastic connector on the engine side that has aprox 44 pins inside. If you disconnect that from the controller and reset that could solve you problem. I know it solved mine. You can't miss it as all the brake lines enter the controller on top and the connector is vertical towards the engine.
