Old May 12, 2013 | 08:13 PM
onehundred80
Default Re: Konis installed, car feels spongy / wobbly
Originally Posted by FUBU
Thanks for the replies. I am replace the whole draglink, lower ball joints and idler arm bushing next weekend. Inner bushings on the drag link is a *****, as you must buy the whole drag link. I changed everything except for the inner. And they are of course the ones being bad.
Anyways, one of the konis ate leaking green goo. So will teplace it this weekend aswell. But one q, i have some small amount of liquid under the "hat" top of damper where you put the plastic piece to turn the firmness. Is that normal. Is on all four.
Just drove it and I think draglink, idler arm and 4 wheel alignment will solve ghe dilemma.
If you mean around that flat little key thing that gets turned when you adjust them then the answer is no.
