Re: won't start......then does......dealer stymied
Check the solder connections on the RCM (Relay Control Module). Sounds like the culprit. You need to look at them under magnification - normally the naked eye can not see the cold solder joints. Search on here for RCM and "No Start" and you will find a thread with repair instructions that takes $0 and about 10 minutes.
RL
