Old May 17, 2013 | 01:12 PM
+fireamx's Avatar
+fireamx
Default Re: Spoiler on Coupe.
Originally Posted by UK ken
Is it possable to adjust the speed at which the spoiler activates?
I perfer the lines of the xfires rear end without it..Yes, I could remove the fuse..But above 80mph I feel its useful.
I just don't want it in view before 80 mph..any thoughts.
UKKen
Hi Ken, it's very simple to install a "Kill Switch" to your rear spoiler.
Just tap into the fuse box on "Your" passenger side, locate the spoiler motor fuse, and simply splice in a wire in place of the fuse.
Attach an inexpensive manual on/off switch inside the interior, and simply flip the switch when you want to activate your spoiler. Don't forget to in install an "in-line" fuse between the fuse box and the on/off switch.
Disclaimer: Performing this radical modification may turn your car into an undriveable, unstable, spinning object at speeds of 65 mph or greater, so make this modification at your own risk.
(FYI, I've been lucky, no problems to report since I did mine in 2006). There is an audible warning to remind you the spoiler isn't activated at speeds above 90 mph.
To be on the safe side, I do raise my spoiler when travelling at highway speeds when it's raining, or very windy. Good Luck
