Old May 19, 2013 | 02:36 PM
velociabstract's Avatar
velociabstract
Default Timeslips, before the pop.
As you can see my car is consistent. If you look at the RT you will see a few times I stayed waiting until I had the rpm's just where I wanted before leaving. I was trying different techniques to learn (or confirm) what works best. I alternated running with and without the water/meth injection too. Little to no difference. Strangely the AFR's didn't vary much last night. Usually I'm around 13 without meth. I was in the 11's for all the runs. With meth I was seeing 11.5 AFR's and hardly varying up or down. Without the spray I hit 12 a few times but only for a moment.
The GoPro was supposed to be running but I's got nuttun. It seems when I erased the SD card before heading to the track, something went horribly wrong.
All I can say is 11's don't fall into your lap, you've got to hunt them down.
Les
