Old May 19, 2013 | 08:50 PM
Infinity's Avatar
Infinity
Default Re: How to Remove all Silver Interior Parts
lift trim around shifter with plastic wedge.
lift window control trim piece
Open the armrest glove box and remove two screws at the back of the lid, two 10mm bolts at the bottom under the carpet liner (small micro screws under lid to remove silver top)
Remove screw at the front edge of console just behind shifter. Lift out console (small micro screws from underneath to remove solver trim
Remove radio with Mercedes radio keys
Remove screws that hold in bezel inside radio opening
Remove two screws below switch panel
Pop out main trim panel
Remove two crews from under vent...remove vent
Remove screws above switch panel/ashtray...remove (you may have to push the sides of the stalk to be able to wiggle free)
