canadablue
My 2004 crossfire w/ 125K miles leaked a LOT of transmission fluid onto the garage floor while I was away for 2 weeks.
The AAA approved transmission repair shop said I need to have parts replaced for $510!!!
He explained to the foolish woman that the plate under the transmission box needs to be replaced because the leak goes through it to the rings. He said he won't charge me for labor, but the part is expensive. He ordered the part Friday and I am supposed to go in Monday morning to have the work done.
Please advise me - is this a possibility or do I really only need a $9 O-ring replaced?
Kristinjsharpe@gmail.com
It is completely possible you may need to change out all the parts. The issue with mine necessitated these replacements. It wasn't because all the parts were bad it was because they couldn't get the $20 connector out and had to break the entire unit and replace it. They quoted me 2400 dollars. Luckily mine was covered under warranty. The key for you is if you will be able to get the connector out (if indeed it is the connector) you should be able to just put the new one in and drive. Good luck
