Old May 21, 2013 | 12:39 PM
onehundred80
Default Re: 61mm pulley stuck
Originally Posted by alaxfire
maybe a propane torch and mildly heat the pulley ?
No, it's the center race of the bearing that is causing the problem.
With the tight tolerance on these things the pulley must come off parallel to the bore axis, otherwise it ***** and locks up.
