Old May 24, 2013 | 10:43 PM
onehundred80
Default Re: AC/Heat won't turn off
Originally Posted by bottera
moved to NYC a month ago, came home, and started to drive my car. When I was driving i noticed the heat wasn't working so I hit the reset button and it started to work. I thought everything was fine, but when I turned to **** to make it go off it didn't (it works on all settings and changes strength).
Now, when I got home and turned off the car completely it keeps running and won't turn off at all. I have let the car sit for 20 minutes and it is still running. any ideas on why this is happening and how to stop it?
Reset button? Do you mean REST button, click it off and that may solve the problem.
From the owners manual.
Air Recirculation/REST
This mode can be selected to temporarily reduce
the entry of annoying odors or dust into
the vehicle’s interior. Outside air does not flow
into the vehicle’s interior. To select, press the
recirculation button. To cancel, press the recirculation
button again.
The system will automatically switch from recirculated
air to fresh air after approximately five minutes at
outside temperatures below approximately 40°F (5°C);
after approximately 30 minutes, at outside temperatures
above approximately 40°F (5°C); after approximately five
minutes, if the A/C button is pressed.
At high outside temperatures, the system automatically
engages the recirculated air mode for approximately 30
minutes, thereby increasing the cooling capacity performance.
Press the recirculation button again to extend the
recirculated air mode.
Residual Engine Heat Utilization (REST)
With the engine switched off, it is possible to
continue heating the interior for a short while.
Air volume is controlled automatically. Select a
temperature for each side of the passenger
compartment. Set the air distribution control switch to
the desired position.
To select, turn the key in the ignition switch to the ACC
or the OFF/LOCK position or remove. Press the recirculation
button. The indicator light in the button illuminates.
This function selection will not activate if the
battery charge level is insufficient.
To cancel, press the recirculation button. The indicator
light in the button goes out. The system will automatically
shut off if you turn the key in the ignition switch to
the ON/RUN position, after approximately 30 minutes,
or if the battery voltage drops.
