Old May 26, 2013 | 09:54 AM
onehundred80
Default Re: intermittent starting problem
Originally Posted by Uk Pete
Same symptoms as mine a few weeks back. It was the Crankshaft position sensor. The diagnostic, part, and fitting cost around the £130 mark.
If this is the problem the bosch part is the one you need.
Cheers,
Pete.
It definitely sounds like the CPS (crankshaft position sensor) we can buy Bosch ones here for around $50. Do not buy any other brand even if they are cheaper, they could be made in China and break just like they are made of china, a waste of money many times so do not take a chance on them.
Get the codes read and it should point you directly to the problem, the red light tells you that a code has been saved so get it read and find out the problem precisely.
With a few basic tools you can repair it yourself for nothing
.(click)
