Old May 26, 2013 | 08:21 PM
onehundred80
Default Re: Mechanical/Transmission Poss Issues/NIGHTMARE time trying to find issue! HELP!
Originally Posted by jtaylortech3
Hey VALK,
Btw onehundred80, I mentioned your comments to my other half and they made a good point that I had forgot. A few months ago before I started having all these problems, that we did notice that there looked a bit like there was water underneath the glovebox. Is this what your referring too?
Justin
That's the spot I'm talking about. The drain below the cowl gets plugged and water enters the inlet for the air behind the AC/heating fan. The water runs down into the passenger side foot well and soaks the TCM (transmission control module) and causes problems.
This is a LH drive car but the drains are similar.
Here's a photo of the drains, they are accessible when the cowl is remo
ved. The drain is under the leaves at the top of the photo. The air inlet is just above the leaves, in the flat area under the windshield.
