Old May 27, 2013 | 02:37 PM
green24u's Avatar
green24u
Default Re: Long bar on the inside of door panel broke
Sorry about the bad link. Problems with the door pull is some what common with the XFire. The door pull comes apart at the seam. Once the front piece is removed there will be (2) screws that need to be removed The door panel needs to come off in order to get to the plastic tabs holding the pull to the panel after the two screws are removed. There is a very good STICKY in the INTERIOR section with pics describing the process. Also try a search on DOOR HANDLE REPLACEMET. A lot of info here also.
