Airscape
When you lower you also gain negative camber all around. Some people stay in spec, others do not. The main problem is that camber is not adjustable using stock components. For the front if you are only a little out of spec the mercedes camber bolts can be used. If those don't get you in spec the other option is the K-Mac kit. In the rear you can go with DIY or custom made adjustable camber arms or there is a k-Mac kit for the rear as well. Also do your homework on trimming the bump stop and spring pad sizes. There are several alignment and lowering threads to brows through. If you install and do nothing you will most likely have to replace tires quickly.
This is what -2 will do to your tires up front. Had these on for about a year after eibach install. Camber bolts only got me to -2 on the driver side.
This is mine on eibachs and konis. I have increased spring pad sizes since the pics so it sits a little higher now. Also running bigger tires up front. basically Snug 2 finger gap in the back and one finger up front.
Those are a lot of great pics and responses to my thread I'm just looking for a low price way to lower the suspention on the car. I love the car but I do think that it could be lower in the front and the back. I been busy working on my bikes soo I haven't had time to be on here worried about the car but I appreciate the post. Get back at me with a response when u get a chance.
