Re: How to Remove all Silver Interior Parts
As long as you got the two above the radio you should be good unless you have an aftermarket unit. The cage that holds the head unit needs to be removed as well in that case. Usually it's just a couple of tabs. The only other thing is the switches for the heated seats etc, they snap onto that silver trim so if they are caught up on something it may seem stuck. Get some slack on the cables and you should be good otherwise each one of the switches has two tabs (one on the top, one on the bottom. You should be able to punch them together one at a time to get the block of switches released.
