Old May 31, 2013 | 04:51 PM
rcompart's Avatar
rcompart
Default Re: SS brake lines: Goodridge or Stop Tech?
Originally Posted by turbomar
If you dont want to get into a pissing match, should you be calling other brake flex lines garbage?
The Magnum might not be the right choice for the track but I'm sure they are plenty good for street use
If you'd have had the fine opportunity to fill your shorts and empty your wallet as a result of a cheap stainless line failing, you wouldn't be arguing with me.
And as for not being good enough for the track but plenty good for the street, there is a higher probability of it being seen before catastrophic failure on a track car than one only street driven.
