Thread: No High Beam
Old Jun 1, 2013 | 02:31 PM
ala_xfire
Default Re: No High Beam
Originally Posted by vbk1
Hi, I an new and hope I have this question in the correct place.
I just purchased a 05 convertible, It does not have high beams, low beams ok.
I can use the passing position of switch and the high beams come on.
Is there a way to test the switch or is there a relay bad ?
Thanks,
check fuse 3 & 5 in the ICM, these are behind the coin operated removable panel at the left side of the dash that you can see with the door open.
ICM = Illumination Control Module, fancy name for the headlight switch assembly.
