Old Jun 5, 2013 | 10:54 AM
MrMoPar's Avatar
MrMoPar
Default Re: Took out engine put it back won't start
If you cracked the oil pan, you better be checking the sway bar, lower suspension, and crossmember as you have to get through them plus the belly pan to get to the oil pan. Also check that upper pan as they are so easy to break.
