Old Jun 5, 2013 | 05:41 PM
ala_xfire
Default Re: Something broke need Help
Originally Posted by waldig
ROB can you hear us now??? Should be a gusset plate to fix this and bolt it on over a larger area, like I did to my seat. Wdy
Woody, I took a look at my N/A roadster, and it appears that the broken bracket in the pictures is a welded on piece that has the rubber grommet bracket bolts WELDED into it on the inside BEFORE it is welded to the frame. I don't think a gusset plate will help.
There would have to be some sort of additional brace plate that has holes for the existing bolts and 4 more holes to bolt through the floor pan. The existing bolts have about 1/2" extra thread showing, so this may be possible.
