Re: Help! Strange noise
Thanks for all the help!
Listen to this:
I was able to locate parts (on a Saturday + it is royal wedding here) but prior to purchase I felt like lifting the car up. Prior I had only looked underneath it when being on the ground.
When lifted, I started to rotate tires( in neutral) and saw that flex discs are a ok. But here is the thing.
The rear tire was loose. Not a little either.
So I exchanged bolts to new ones and screwed it back on. Solved the problem.
I do not want to speculate but I will def kick all 4 tires every time I hit off.
