Repairing BCM?
I just bought an 04 Crossfire. It's got 72k and when I bought it, I knew the passenger window sometimes wouldn't go up. Sometimes you have to push the up button for ten minutes to get the window to roll up. The previous owner had bought a new power window regulator and hadn't installed it yet. It was part of the deal that he would throw in the regulator and I'd install it. So I got around to that today, and found out it wasn't the regulator that was bad. I used a jumper cable and the window goes up and down fine.
When I pressed the up button, you could hear a rapid clicking sound coming from the rear right of the engine compartment. After looking through the service manual, I found that the Body Control Module has a couple relays for the power windows. Obviously one of the relays went bad. So I opened up the BCM and see that everything is soldered in. I can see there's 3 relays on the upper right side of the board. All of the connections looked to be okay. Is it possible or has anyone ever tried to repair the BCM by just putting a new relay in? Or would I just be better off buying a new BCM?
