Thread: Help!
Old Jun 10, 2013 | 07:08 PM
ala_xfire
Default Re: Help!
The P2098 does say "too lean".
Might this possibly be due to low fuel pressure to the injectors, or clogged injectors ?
You can test the fuel pressure at the test point right front of the fuel rail on top of the engine.
54 to 61 psi is what you want to see ........
Maybe want to change the fuel filter just for grins ......
Could also be a catalytic converter ( or more than one ) going south :
From the manual :
CATALYST MONITOR
DESCRIPTION - To comply with clean air regulations, vehicles are equipped with catalytic converters. These converters
reduce the emission of hydrocarbons, oxides of nitrogen and carbon monoxide.
Normal vehicle miles or engine misfire can cause a catalyst to decay. A meltdown of the ceramic core can cause a
restriction of the exhaust. This can increase vehicle emissions and deteriorate engine performance, driveability and
fuel economy.
The catalyst monitor uses dual oxygen sensors (O2Ss) to monitor the efficiency of the converter. The dual O2S
strategy is based on the fact that as a catalyst deteriorates, its oxygen storage capacity and its efficiency are both
reduced. By monitoring the oxygen storage capacity of a catalyst, its efficiency can be indirectly calculated. The
upstream O2S is used to detect the amount of oxygen in the exhaust gas before the gas enters the catalytic converter.
The PCM calculates the air/fuel mixture from the output of the O2S. A low voltage indicates high oxygen
content (lean mixture). A high voltage indicates a low content of oxygen (rich mixture).
When the upstream O2S detects a high oxygen condition, there is an abundance of oxygen in the exhaust gas. A
functioning converter would store this oxygen so it can use it for the oxidation of HC and CO. As the converter
absorbs the oxygen, there will be a lack of oxygen downstream of the converter. The output of the downstream O2S
will indicate limited activity in this condition.
As the converter loses the ability to store oxygen, the condition can be detected from the behavior of the downstream
O2S. When the efficiency drops, no chemical reaction takes place. This means the concentration of oxygen
will be the same downstream as upstream. The output voltage of the downstream O2S copies the voltage of the
upstream sensor. The only difference is a time lag (seen by the PCM) between the switching of the O2Ss.
To monitor the system, the number of lean-to-rich switches of upstream and downstream O2Ss is counted. The ratio
of downstream switches to upstream switches is used to determine whether the catalyst is operating properly. An
effective catalyst will have fewer downstream switches than it has upstream switches i.e., a ratio closer to zero. For
a totally ineffective catalyst, this ratio will be one-to-one, indicating that no oxidation occurs in the device.
The system must be monitored so that when catalyst efficiency deteriorates and exhaust emissions increase to over
the legal limit, the MIL will be illuminated.
