Old Jun 12, 2013 | 09:14 PM
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: Possible Rear Woofer Replacement!!
If their rated at 2 ohms then they'll pair up fine with the amp.
Could you flush mount them - letting them protrude say about 1/2 inch toward the seat? Use some MDF to space and seal? There is a little room to spare.
How much room would you need give the magnet a 1/8" clearance from the rear panel?
Could you cut some 5/8" MDF and mount to both sides securing the MDF to the top and bottom panels - thus making a airtight box? Might be a bit tight and you might need some RTV to seal the seams. then you could dampen the entire area with insulation.
Install and test - might possibly need a port - but it could thump...
