Old Jun 13, 2013 | 11:54 PM
velociabstract's Avatar
velociabstract
Default Video Solo 1 June 9, 2013
I added some bump stops from FatCat Motorsports on all 4 corners of my car before this event. Harder on the front with spacers and softer on the rear. The idea was to limit the travel and control the dive and lean to an extent. I measured about an inch of travel before contacting the bumpstops. The result was the rear of the car wanted to come around on every corner. Watching the video you can see some obvious moments. I was missing the apex often, not because the front wasn't sticking but because I was afraid of the lack of traction on the rear half of the car. This was also the heat when the un metered leak became a torrent and the supercharger whine changed, among other things. The investigation points to loose supercharger to head bolts as well as the i/c outlet to Y pipe hose having an issue. Regardless, the video is interesting and I hope it's enjoyed.
Les
