Old Jun 21, 2013 | 07:58 PM
oledoc2u
Default Re: P0500 - Need advice on fixing.
wing must work off the speed sensor....I have SRT's so I am not familiar with it, but would be my guess. That sensor or a wire to the sensor may have voltage problem throwing the code, and causing the problem. Check your connections all the way up to the fuse box...corrosion could be the problem. At least that is an easy start to look at first...
