Old Jun 21, 2013 | 10:30 PM
SRT6 Gang Member's Avatar
SRT6 Gang Member
THREE 6S
Default Re: Hot water testing of the parallel and stock IC.
Originally Posted by Billy22Bob
Will this wake the sleeping bear?
See image attached - I've included both USImperial and SI units
For those not willing to read the original post,
Waldig ran hot water through his IC whilst sucking air through the air side and measured the temperature drop of the water.
Good technique, but it needs to be caveated with the fact that the air was drawn through the IC at what would appear to be a much lower rate than what would be seen on a WOT event.
Based up on the heat the water losses, my guestimate indicates maybe 125cfm versus a WOT which is up around 500-800cfm (depending on your setup).
Not sure what's going on, but I get different results to Woody (all respects).
I think my calcs stand up but am willing to accept counter if there is any err.
The important conclusion I found was for the Series Format IC, when the flow was doubled, the cooling effect increased by 9.8%.
It would be good to do 200-300 cfm or even 500....but we'll see.
For those of us in the minority.....
Lets get a little more techincal....the others can switch off.......yawn....ZZZZZZZZZzzzzzz......
Increasing the flow of air or water, increases the reynolds number.
The water and air heat transfer coefficients are also directly related to their Reynolds number.
That is - increasing the flow, increases the reynolds number which increaes the heat transfer coefficient.
However doubling the flow of water doesnt necessarily double the heat transfer coefficient as shown in the results. In the results, doubling the flow of water only piked up 10% in additional heat.
The same would apply to the air.
It will be interesting to see how this develops.......
Makes sense, I relate it to the NW Intakes. The dual does not double the amount of air flow over the single but it does provide more air. It's up to the individual to decide if the difference between the two is worth the extra time & money, same concept here.
BTW- I enjoy your analytical prowess.
