LVXF
Other than a really deep pit near the high beam passenger's side, the lenses look good. I used an LED shop light and the finish looks smooth. Just ordered HID kit so will wait a few days for it to arrive. Shop said to let the headlight lenses cure for a few days so timing is good. Will be dusting off Max's sticky on install. Will also be hard-wiring my Garmin behind the glove box. Car should look really clean by the end of next week.
Don't hard wire the Garmin !
I connected a female cigarette lighter adapter to the glove box light and just routed the standard Garmin cord with male cigarette lighter plug to it inside the right removable panel.
That way, you can still remove the Garmin and use in another car if you need to.
( the glove box light is common to the installed cigarette lighter plug and is hot in accessory / start / run )
