Old Jun 27, 2013 | 10:20 PM
gregcormier's Avatar
gregcormier
Default
Originally Posted by oledoc2u
crank but no start is usually the crankshaft position sensor... under $50 fix...and you need to replace it anyway...so worth a try....good luck
Would a bad CPS set a code? The mechanic working on my car is very knowlegeable and would have jumped at easy fix. I will pass that suggestion on to him just in case. Thanks for the reply.
