Old Jun 29, 2013 | 08:34 AM
onehundred80
Default Re: AC blows hot? Weird idle/lope at start? Fixed mine!
Originally Posted by martyfa
Finally fixed my issue of only blowing hot air. Whether the temp controls were on blue or red it would only blow hot and no AC. What I did was take the aluminum caps off the heater control valves which are located directly behind the overflow tank, careful not to drop any of the 5 screws. After lifting the caps off I lifted the yellow wrapped magnets off of the valves, which is one piece and then cleaned the base that the magnets sit on. I pulled the valves out careful not to lose the springs sprayed them with a lubricant and reinstalled. Put everything back together and now I have AC and control of my cabin temps.
Thanks for the final answer to your problem.
One question, when you take the aluminum caps off does the coolant leak out?
I polished these caps and I did it with them in place as I thought they would leak.
Just as an aside, there is an article that I copied that shows how to repair the actual valves in this unit using Pop Rivets. It would save a lot of money if you did this fix instead of buying a new valve. Click here.
