Old Jun 30, 2013 | 09:20 AM
NjRichieRich25's Avatar
NjRichieRich25
Default Re: CAI Problems Solved!
Originally Posted by alaxfire
Richie, you will find that the OEM engine cover is restrictive, even with the air filters removed, but if you are going with that anyway, make certain you are getting a good seal between both the removable covers and the main cover. This has been an issue in the past, seems the plastic covers can warp.
A Needswings or DIY CAI is the preferred way to go, the part that is hard to find ( but can be found ) is the 90 degree 3" silicone elbows. If you keep all the OEM plastic junk from the throttle body and up, it's hard to connect to,
If you drop the plastic stuff, then you are stuck with how to mount the MAF/IAT sensor.
Rob at Needswings has all this covered, albeit at a price .....
http://www.needswings.com/productimages/xfnacaigray.jpg
If you wanna go all out, take a look at maxcichon's homemade DCAI :
CrossfireForum.org - maxcichon's Album: Member Galleries - Picture
At any rate, you will soon also want a 74MM throttle body upgrade, and a EuroCharged tune.
Cool, thanks Alex! Very helpful info!
Are you referring to a 90 degree elbo to mount coming off the MAF/throttle body? If so, yes that was my biggest hurdle when deciding how to cut out the restrictive engine cover and come straight from TB. Basically what I'm trying to fabricate for now is tubing which will connect to my two cone filters in front of the radiator and connecting to tubing coming off off engine cover (the real problem rest in the ability to fit through the small, oblong shape on both sides of the radiator. I figure once I can do that, I can easily just cut out the cover and go straight to TB (assuming I use the 90 degree elbo).
