Old Jun 30, 2013 | 11:52 AM
onehundred80
Default Re: Mysterious gas leak....Comes and goes
Originally Posted by Buggin
You don't want to intentionally overfill your tank. This can cause the charcoal evap canister to flood and the car to not run properly until it dries out or you change it.
Correct me if I am wrong, sadly it happens , but the tank cannot be overfilled because of the overfill check valve. When the tank is "Full" this check valve closes the tank to more gas and the gas will spill over at the filling tube and run onto the ground via the tube in the gas cover unit. This happens if the gas nozzle does not shut off or you lift the nozzle out of the gas filler tube. If the gas over fill flap is jams then the tank can over fill and all bets are off. The tank is quite complicated and is a sealed unit, if it fails you have to replace the whole unit.
