Old Jul 1, 2013 | 04:53 PM
Valk
Default Re: Engine Temperature
Does the engine cooling fan run when you have the A/C turned on ??
The fan will run at low spreed with the A/C on no matter what the outside temp is
That's how I periodically check mine to see that it is operating and the relay is working.
Also if the gauge creeps a bit above half way that is normal but by then I think your fan should be on.
