re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Reliableron
Rekcah has put the repair PDF file in post #1 - PDF Sticky Ignition Key Fix_v2.pdf use this and you will not have problems.
Correction to a correction, Rekah could not put his PDF in the first post, I am assuming a mod, probably Valk did.
All thanks go to Rekah, RR, drhrsh et al.
Correction to a correction of a correction, Valk put the PDF in the first post. It says so.
