MMZ_TimeLord
I did NOT have to actually remove the lower console assembly. I did have to unbolt/unscrew most of it's anchors so I could drop it down and remove the upper part located just below the gauges and steering wheel column.
I updated the OP with this information. Hopefully it's a little clearer. I found a picture to post here to show what I had removed.
Hope that helps.
Hi and sorry my English, because i'm Russain
Today, I started to dismantle Instrument Panel.
You wrote I don't have to take out steering wheel, but I cannot pull put the control panel without taking out the steering wheel.
Or did you take out the glass from the control panel first?
and what key is needed to remove the steering wheel?
Thanks!
