ITF36059
Where did You buy the RCM? I think my 05 is experiencing this problem, but it behaves slightly different than described here. I had my 05 limited shut down at an intersection. when I turned the key, all the warning indications came on at one time. cranked the starter, the starter would turn over, but not start. turn the key back and the starter is still cranking! turn the off. Wait a minute, then it starts fine. Got it home ASAP and it's been in my garage since.
Anyone experience this?
Mike
Those symptoms describe a failing CPS ( Crankshaft Position Sensor )
Replace with a Boshe, accept no substitutes.
( the RCM - K40 symptoms is you turn the key, get dash lights, then go to start position and get nuttin )
