Thread: 2004 V8 6-speed
Old Jul 11, 2013 | 12:04 PM
  #83 (permalink)
sk8erjosh09's Avatar
sk8erjosh09
Default Re: 2004 V8 6-speed
She Cranks!!!!!!!!!!!
Ok, so I cheated. I did what Bob did and jumped the starter solenoid ground with a push button. I tried new Immo data from Karim and went into DAS, when I turned the ignition on I heard the fuel pump. I went and checked the fuel rail and sure enough there was fuel (fresh, I drain before I begin with each idea)...Not sure why she didn't start but it could be sensors and such. I will check diagnostics when I get home tonight and maybe pull the cam or crank sensor from the V6 and swap the V8's.
Also, this is a temporary fix btw. Apparently the shop that has Bob's old car right now in Phoenix claims they figured out the key/Cruise problem. Hopefully they will work with me and tell me the solution so that I can do it myself. I have not paid anyone for services regarding the swap yet and I do not plan to start. I have only picked a lot of smart brains. Not to be rude to anyone but this knowledge should be shared to this community and if I figure it out completely on my own then I know exactly what to tell people or help them with when it comes time for the next one
