mj24724
I have a 2004 crossfire the rear tires have wore from the inside to the outside,wore off tread on the inside leaving some tread on outside.I just was wondering what could cause such wear as I am replacing them with new tires and don`t want the same thing to happen.thanks for any help you can give me.
Has the car been lowered ?
Do you carry heavy stuff in the rear all the time ?
Do you run the tires properly inflated ?
It sure sounds like the rear camber is waaaaaay off.
You have this : /---\
You don't want this : \---/
You want this : |---| within 1 to 1.5 degrees.
