Old Jul 13, 2013 | 12:00 AM
JesseJamessrt6's Avatar
JesseJamessrt6
Default Re: Resetting DBL Wrench service symbol
I checked out the Ultragauge, you keep that in your car all the time for all the other benefits?
It is the same reset process for service A or B. I still can't get it reset.
Here is the process from the manual, same as above
Perform the following to reset the counter:
1. Turn the ignition key to the ON/RUN position.
2. Within one second press the ****/button to the left of the display twice.
3. The present status for days remaining or distance traveled is displayed. Within ten seconds turn the key to
OFF.
4. Press and hold the ****/button to the left of the display, while turning the key to ON/RUN again. The present
status for days remaining or distance traveled is displayed once more. Continue to hold the ****/button to the left
of the display.
5. Release the ****/button to the left of the display. After approximately ten seconds, a tone sounds and the
display shows 7,000 miles (11,000 km) for approximately ten seconds.
Here is the service required from the srt6 '05 manual
DESCRIPTION - MAINTENANCE SCHEDULES
SCOPE OF WORK FOR “A” SCHEDULE MAINTENANCE SERVICE
Oil Change
² Change the oil and replace the oil filter
Maintenance
² Lubricate the hood hinges, hood latch, and secondary hood latch
² Reset the FSS Display
0 - 8 LUBRICATION & MAINTENANCE ZH
Function Check
² Horn, hazard warning flashers, turn signals, and indicator lamps
² Headlamps and exterior lighting
² Windshield wipers and washer system
Inspection
² Check front and rear brake pads for lining thickness
² Check tires for damage and general condition
² Check tire inflation pressures and correct if necessary
Fluid Levels
Check fluid levels for the following systems and correct if necessary. Should there be a loss of fluid that cannot be
explained by regular use, trace and eliminate the cause.
² Engine cooling system (check corrosion inhibitor/antifreeze)
² Hydraulic brake system
² Power steering system
² Windshield washer system
SCOPE OF WORK FOR “B” SCHEDULE MAINTENANCE SERVICE
Oil Change
² Change oil and replace filter
Maintenance
² Rotate tires
² Replace dust filter
² Lubricate hood hinges, latch, and secondary latch
² Reset FSS Display
Function Check
² Check seat belts for damage and proper function
² Test hydraulic brakes and check parking brake function
Inspection
² Check condition of front and rear brake discs
² Check major underbody components for leakage or damage (if there are signs of leakage, determine cause
and repair)
² Check condition of front axle ball joints and rubber boots
² Check condition of steering components and rubber boots
² Check underhood components for leakage or damage (if there are signs of leakage determine cause and repair)
² Check condition of accessory drive belt
² Check headlamp aiming, adjust if necessary
² Check windshield wiper blades, replace if necessary
Fluid Levels
