Re: Code P2098
p2098 repair - remove maf sensor housing, clean and die electric silicon grease the gasket under it, clean maf, reassemble, put 1/4 inch screw under housing clip to hold housing tight against intake pipe. No vacuum leak, no p2098. Took me awhile to figure this out. Good luck, Double R
