Thread: Alignment Bolt
Old Jul 14, 2013 | 06:33 AM
MJPowers's Avatar
MJPowers
Default Re: Alignment Bolt
The lower control arm is in a "Y" shape, with the top of the "Y" on the engine side of the car, and the bottom at the wheel. The side of the top of the "Y" that faces the front of the car is the bolt that adjusts the camber, and the side that is toward the rear of the car adjusts the caster.
With the alignment bolts, you get about .3 to .5 degrees change. I installed mine, and you can manhandle the control arms with a crow bar a little to get some variation. I've seen posted on the forum several different accounts for how much change the bolts give for camber.
To reduce negative camber, install the washers with the protrusions on the wheel side.
To increase negative camber, install the washers with the protrusions on the engine side.
On the left side, you said you have -1.7 of camber, so install the washers with the protrusions toward the wheel. This should get you to -1.2 to -1.4.
You said the right side is -.8, so install the washers with the protrusions toward the engine. This should get you to -1.1 to -1.3.
Make sure both washers are seated into the detents in the frame when tightening. You have to manually move the control arm with some type of pry-bar, and the washers can get bumped out of their indentations.
If you are going to do it yourself, make sure you have good jack stands, because you may be moving the car some by forcing the control arms into place.
Good luck, and remember the second side will take about 1/2 the time as the first.
