Thread: Alignment Bolt
Old Jul 18, 2013 | 07:04 PM
Airscape's Avatar
Airscape
Default Re: Alignment Bolt
Originally Posted by vbk1
I installed the bolts in the front bushings, but if I don't replace the rear bolts the same direction wont it change the caster ?
Thanks
I only did the camber bolts and my caster was still in spec. You can get a free alignment check and see where you end up. If the caster is out then you can get a couple more bolts and install as needed.
