Old Mar 21, 2006 | 02:15 PM
xfire1's Avatar
xfire1
Default Re: Front License Plate Bracket Install
Originally Posted by lochmoy
Thanks for the info!
The screws I received are machine screws w/o a self tapping tip. It sounds like I would be best off trying to get to the back side to install a washer/nut to avoid problems later on. I bet that will be a chore!
Is there a member with a Factory Service Manual that could look if the front bracket install procedure is detailed for me???
Thanks in advance!
You can get a service manual from the forum... 2 members were kind enough to post it on their website for downloading... check out:
https://www.crossfireforum.org/forum...service+manual
go to page 2 and 3 you will see the links there.
good luck its over 3,100 pages PDF.
j.
