Old Jul 22, 2013 | 04:10 PM
jtaylortech3's Avatar
jtaylortech3
Default Re: Well after MONTHS of issues/FINALLY getting RESOLVED! Have NOW run into MORE issu
Well, luckily, the CPS issue ( if it is that ) is easy to fix, and not too expensive.
It is about a 20-30 minute DIY project, and should cost between $45 and $65 ( US ).
Just make sure you get a Bosch sensor.
There are threads on here about the DIY with pictures.
You don't necessarily need a 'Chrysler' part, any Bosch CPS for a MB 112 engine is the same.
Yeah good news that this part is not expensive atleast (makes a change) and hopefully it is that then. Not sure where I would get the part from in the UK but will to have a look around! So just to verify, based on what I have said and fact the check engine light comes on and shows this "crankshaft position sensor" code is that a pretty much a given that this will be the issue? Or can the obd scanners sometimes be wrong with the code it shows? (sorry if that sounds like stupid question but not familiar the obd scanners until recently).
Thanks,
Justin
