Old Jul 22, 2013 | 04:24 PM
ala_xfire
Default Re: Well after MONTHS of issues/FINALLY getting RESOLVED! Have NOW run into MORE issu
Originally Posted by jtaylortech3
Yeah good news that this part is not expensive atleast (makes a change) and hopefully it is that then. Not sure where I would get the part from in the UK but will to have a look around! So just to verify, based on what I have said and fact the check engine light comes on and shows this "crankshaft position sensor" code is that a pretty much a given that this will be the issue? Or can the obd scanners sometimes be wrong with the code it shows? (sorry if that sounds like stupid question but not familiar the obd scanners until recently).
Thanks,
Justin
Manual says : P0335 -
When Monitored: Engine cranking or running.
Set Condition: No Crankshaft Position (CKP) signal is present during engine cranking and at least 8 Camshaft Position Sensor (CMP) signals have occurred.
Looks to me like a bad harness connection or a bad CPS sensor ......
