Old Jul 25, 2013 | 07:38 PM
stlouistrucker's Avatar
stlouistrucker
Default Re: PLEASE HELP...START ISSUE!!!! ECM? RCM? Skreem?
Originally Posted by Mrmiata
I'm going to guess your standard shift..
My automatic (with autocrank) was taking that "extra second" or so to fire off when cranking.. for about a week. Spoiler already up over abs issues.. fired off one morning for work-40 minute drive no headlights needed.... stopped for breakfast run.. then just got one click.. autostart relay.. jumped and got to work and replaced battery at lunch (after another jump).. problem solved.
I also have the automatic and yes it was taking an "extra second or two" to fire when cranking. After jumping it this afternoon, I took it to Advance Auto where I had bought the battery. They had me turn it off so they could check the battery. They said it was a little low on charge but the battery was good. He then asked me start it up so that he could check the alternator. It started instantaneously. He also said that the alternator checked good. He said there must be something draining the battery. Can the RCM problem cause the battery to drain?
