Old Jul 26, 2013 | 01:02 PM
ichon's Avatar
ichon
Default Re: Ignition Locked - New Cylinder Cost
Originally Posted by ssammons
After describing the problem ( steering wheel, ignition & transmission locked), my mechanic advised that he probably needs to replace the cylinder on the ignition.
Any advice on cost expectations.
Can the transmission be unlocked so I can push the car back to be towed?
Slide the silver and black "RNDP" cover forward, find a small notch under the cover, push it with a screw driver and it will release the gear lock and allow you to put the car in neutral. The ignition solenoid should run about $800. Try to get it from a MB Dealership as opposed to Chrysler because they have them in stock. Chrysler has a mark up on that part. Labor is gonna cost ya a bit as well. Good luck.
P.S. The tow truck operator should know how to unlock the tranny. They do it all the time.
