Old Jul 27, 2013 | 02:39 PM
jtaylortech3's Avatar
jtaylortech3
Default Re: Come on who can answer this puzzle re a BAS ESP light problem
Outside shot, but the only thing that comes to mind :
Usually the low profile tires on our cars are directional tires.
It's possible that by mounting with the rotation direction wrong, the previous wear pattern now causes the smooth circular rotation to be a bit interrupted, which in turn results in non-linear signals from the wheel speed sensors to the BAS/ESP module.
Like I said, just a wild a$$ guess.
I was going to suggest and say the same as what ala_xfire said! In my experience it will be the wheel speed sensors that are causing this, they can be pretty sensitive! When the BAS/ESP light comes on there is a "trick sequence" involving turning the steering wheel to get the light to reset and turn off. I have done this previously when I triggered the wheel speed sensors when I was doing some work on the car, did that sequence and light hasn't been on since!
