Re: Changing Door Speakers
Door speaker is a 6.5"
If you are using the factory amp then look for speaker systems with an impedance around 2ohms to ensure you maintain power output levels (factory setup is a 2ohm setup, normal aftermarket sits at 4ohms) Infinity and JBL products in the reference and gto lines drop right in and have the same screw hole locations and meet the 2ohm criteria
